how can change cabinet address?
khorasani
Post by khorasani »
Hi everybody,
I have two cabinet with 1 address(address(1)),i want network them(class A),I have this error(attached file)How can I change cabinet address?many thanks for help.
please find attached file.
alpha bravo
Re: how can change cabinet address?
Post by alpha bravo »
You can change node address by performing a single-step database download to the CPU first and select "Force operation" when prompt, then download loop controllers.
Note: from your attachment pic actual loop controller is 3-SSDC not 3-SSDC1, that means you need to reconfigure it as such.
old_tech
Post by old_tech »
AB, tech support said the 1 doesn't matter
khorasani
Post by khorasani »
Dear alpha,
many many thanks,your help was useful,the problem has been solved now.
thanks again,
Mehdi.
khorasani
Post by khorasani »
Dear old_tech,
thanks,the problem has been solved now.
thanks again,
Mehdi.
