Ext _database_ incompatibility error
Nirujan
Post by Nirujan »
any body can enplane to me why this error is coming
FireTech
Re: Ext _database_ incompatibility error
Post by FireTech »
0022 Ext Database Incompatibility:
CPU Changes to the active state when a different database in one or more network nodes.
-- Did you Compile, Convert and Load only a certain CPU and not All on Network?
-- Did you Forget to Load a CPU?
--- TIP --- Do you know you do not have to Load every SDDC/AADC card every Time you Load? For example, If I am making Database program change , but not adding a device or changing a device type on on SDDC Card, I compile, CONVERT CPU's ONLY, Then LOAD CPU's ONLY.
--- If I am adding 1 device to One Sddc Card: Compile, CONVERT ALL CPU's AND CONVERT JUST THE SDDC CARD YOU ADDED new device to. THen Load All CPU's and just the SDDC Card you Converted. THE KEY IS THE "CONVERSION".
When you use this method, it will save you valuable time. Especially since you have Several Nodes/Panels.
Nirujan
Post by Nirujan »
Yes right I had loaded only one cpu but I got that error message from same cpu and another one cpu also why?
Nirujan
Post by Nirujan »
Hi please tell me if i commit all the device means what happens will be come ?
Ext _database_ incompatibility error - is what firetech posted and very good info.
"commit all devices" has nothing to do with the database error.
briac
Post by briac »
just download all CPU with the same database
Nirujan
Post by Nirujan »
hi ,
in my one of site est3 installed ,there photo detectors only showing yellow color while map internalization (in mapping icons areas) can you explain its happening.
old_tech
Post by old_tech »
cuz est programmers suck. select 'commit all', then convert and download to the sxdc
