I am facing a problem Detector Compatibility Fault of XLS-1000 Honeywell fire alarm control panel.
we are used all detector of Honeywell XLS-PS/HRS. Now this detector is not available in Bangladesh. then I try to installed SIGA series (EST) SIGA-PS/HRS. But Compatibility Fault Shown in the Fire alarm Panel.
Which device we can use instead of XLS-PS/HRS.
Thanking You,
Enamul
Re: Detector Compatibility Fault
akrajib143 wrote:Hi,
Thanking You,
Enamul
need to replace all detector in same loop (to SIGA) and use EST3 dongle to download
[need to replace all detector in same loop (to SIGA) and use EST3 dongle to download]
I have 3-SDU ver. 3.4 & 3.72 Software and Honeywell Dongle.
is it possible to download and programming (SIGA)?
- Contact:
Dear Bro,akrajib143 wrote:[need to replace all detector in same loop (to SIGA) and use EST3 dongle to download]
You can't replace that. Because each brand has a different product. The EST sensor can't replace the honeywell and vice versa.
Good luck,
Hiep Nguyen.
[Dear Bro,
Good luck,
Hiep Nguyen]
What is the solution?
I have Honeywell XLS-1000/200 3-SDU Dongle.
Thanking You?
Enamul
Good luck,
Hiep Nguyen]
Thanking You?
Enamul
- Contact:
Dear Enamul,akrajib143 wrote:[Dear Bro,
Good luck,
Hiep Nguyen]
Thanking You?
Enamul
The solution is:
1. You need replace the detector same as old detector ( this mean is: same type and same brand, may be different model).
2. Then you use Honeywell XLS-1000 software to reconfiguration it.
Can you sale 3-SDU Dongle for me? I need it.
Regards,
Hiep Nguyen.
