Hi All,
recently, i started to use 3-sdu 5.10.1, but i found that it is generating random addresses for cosective devices. what i mean is that consective devices doesnt have consective addresses. this issue leads to difficulty in writing the description.
do anyone have a clue how to overcome this problem.
Thanks in advance.
Addressing in sdu 5.10.1
Re: Addressing in sdu 5.10.1
change the device address in the map
plan a : read in the map. use 'alt printscn' to capture a picture of it. open the picture in paint.
arrange the configure window and the paint picture side by side and add the devices to the database or just write them down.
then use actual/expected form to commit the devices.
plan b: get a barcode scanner and manually scan the codes in. (does that still work?)
It sucks, don't it? 3.74 was the best. now it generates database errors.
Too bad the new programmers aren't as smart as the original ones.
