QuickStart Network Download
hijazih
Post by hijazih »
If I have networkable QS panels, Is it possible to dowload the database via network or I have to download each panel separately.
Re: QuickStart Network Download
no, you will need to load each panel directly it is the same for the annunciator.
hijazih
Post by hijazih »
Thks Leo
raydaviesjr
Post by raydaviesjr »
you can also go in to config in prog on main panel and use save/sync will download all annu
it takes a litte bit of time like 10 min. it may still be easy to go to each annu
so you can load the annunciators via the main control, did not know that.
both types of annunciators? ( LSRA Type and the ones that look like a QS panel)
raydaviesjr
yes you can
rugby
Post by rugby »
Can I download a new annunciator from the main panel
Without doing any setup on the annunciator?
I'm new to the QuickStart panels. But not the EST 3's
No, Quickstart and EST3 are total different
