I upgraded to 3.74 and after all of my analog device sensitivities switched from normal to most sensitive... EST is aware of the problem and this is the reply I got from them :::::
"Thanks for your patience! I did receive a reply from our engineering team, this is a known issue and will be resolved in the next 3-CPU application code. Even though the report shows the wrong information, the detectors are properly set for the configured sensitivity.
Best regards
UTC Fire & Security Technical Support"
Be careful I do not agree with them, the sensitivity is stuck at most and I have had numerous alarms due to this....
