QS-Password invalid, level 3
firediv
Post by firediv »
I have a QS4 and it tells me my password is invalid. Is there anyway to reset it to default 3333?
The QS1 is set at 3333.
getech
Re: QS-Password invalid, level 3
Post by getech »
Log on with password 3253 and then go change your level 4 or level 3 password.
Freaky76er
Re: QS4
Post by Freaky76er »
not sure if you have tried this; cannot remember off hand but you might need the password, still worth a try
Program onsite - open Program in quickstart software on laptop. then from the top, Configure--->Projects, change password and download to panel.
No program - in the QS program, create a new project, configure the panel cards into the program, connect to the panel then upload the panel program. You might need to fix your correlations.. save the program. then at the top do Configure--->Projects, you see level 3 password, change and upload to the panel.
Chanwh898
Re: QS4
Post by Chanwh898 »
Have you try to log in using 4444 then change the other level password?
I think 4444 is the default highest level password
Re:QS-Password invalid, level 3
This is common the last programmer changed the level 3 password within the SDU program.
This is done to stop someone from uploading the panel and making changes or another company from taking it over.
you can use code loader to wipe the panel clear, and start over.
