WinPak - Configuring Multiple Communication Servers
Re: WinPak - Configuring Multiple Communication Servers - Debug
Debug - The Communications Server
I had a problem with a Remote Communications Server and it would only work if I ran this debug program.
to run: Start->All programs->Honeywell Access Systems folder ->Service Debug -> Communications Server
Configuring Win-Pak Pro for Multiple Communication Servers
Attached is a docs from Honeywell.
Use the IP address not the computer name,(On Both computers)
At least to start with. If it works try the computer name.
- per doc -
Note 1: Make sure that you are logged into Windows as a Power User or Higher. Also, you would need to be logged into WIN-PAK Pro with Full rights.
Note 2: Before configuring Win-Pak Pro with multiple Communication Servers, make sure that WIN-PAK Pro is licensed for multiple Communication Servers.
- If you are having problems check post - Winpak Client Can not connect to server
Also
from remote comm server PC:
C:\telnet (IP database server) port
C:\telnet 192.168.1.200 5555
overview:
You set the database server up with the remote comm servers IP address and port (5567)
The Remote comm server only needs the Database servers IP and port (5555)
When the remote comm server starts it asks the database server which port it uses (ie. port 5567)
Multiple Com Servers.doc
MSword docs for Configuring Win-Pak Pro for Multiple Communication Servers
(126 KiB) Downloaded 704 times
