* EST3 - Via Keypad put smokes,pull,etc into ALARM *****
The EST3 panel can put its device into alarm via the keypad
THIS IS A GREAT FEATURE
this only works with the 3-SSDC1 or 3-SDDC1 cards not the 3-SSDC or 3-SDDC
Via the keypad (under test) you tell the device to go into alarm the device then goes into alarm and responses back.
The LED on the device lights, because the device is in alarm.
The device has to be communicating for it to go into alarm.
I use this when I only need to test the response of the device.
I have only put Alarm devices into alarm, I have not activated supervisory
tukalo
Re: * EST3 - Via Keypad put smokes,pull,etc into ALARM *****
Post by tukalo »
yep iv tried that too...command menus, then 8, 4, 1, then enter panel,card and device number and password then you got an alarm and you got your outputs as per your rules...
