WinPakPE upgrade from Winpak2.0
1. Backup the database from the winpak2.0 machine.
2. You will need to know the sa password if SQL is already installed on the new PC.
MSDE - default (master)
How to verify and change the system administrator password in MSDE or SQL Server 2005 Express Edition
http://www.thealarmtech.com/forum/viewt ... f=18&t=246
3. Insert the installation CD
4. When you get to the SQL password and instance, the instance will be left blank.
5. Stop the Services and restore the backup database file.
6. The Program will run in DEMO mode until it is registered, The CD key is inside the "Quick Reference Guide"
7. Within WinPakPE goto Help -> Register. it will open Honeywells main web page, look center bottom for the word REGISTER.
8. The PC name will need to be changed within Configuration->Devices->CPU->Configure(machine name). Before it is changed the panels will be in comm fail.
