QuickStart -Want to make ct-1 disable outputs
QuickStart
I am trying to have a ct-1 disable a few outputs
tried every thing i can think of under correlation
is there a trick i am missing
alpha bravo
Re: QuickStart -Want to make ct-1 disable outputs
Post by alpha bravo »
You should be able to do it using correlation
- Add output group (on the left side)
- (on the right side) on "Devices Activating Output Group" Tab click "Add Device" then select your CT-1
- From "Response" Tab select Response Type "Active"
- Click Disable and select your outputs.
that is what i was doing.
but the disable light did not go on so I thought it was not working
I just tested it and it works good, no disable light on panel
I am going to open nac2 to disable all my outputs
