Hi Gugs,
I'm Trying To use GE System Builder for Obtaining Some Calculation But I didn't Achieve That Properly
I Will Be Grateful For Any Help
GE SYSTEM BUILDER
Re: GE SYSTEM BUILDER
hi,
where do you stuck?
where do you stuck?
THanks Mr.Briac Finally I found Solution But Still Have Some Problems ,There are Some Quotation Requirement Regarding to use
Addressable Break glass_Weather Proof Type I checked There's is not Available ,
I found Old Quotation Solved this Problem With using Conventional manual Call Point+CT1 Module , It's Right ???
hi,
you are right, use it.
regards
regards
