Status logs
Re: Status logs
when there is wiring problems you will get "Mapping pending" and it will not go away.
open the SLC loop so there is only a few devices and see if the Mapping pending problem goes away.
if so add devices until you find the problem, loose smoke head, maybe the feed to a base is miss wired.
take your time and look at each device, you will find the problem
khorasani
Re: Status logs
Post by khorasani »
Leo wrote:when there is wiring problems you will get "Mapping pending" and it will not go away.
Thanks Leo.
khorasani
Status logs
Post by khorasani »
Hi everybody
Im working on EST3 Panels programing,after download the program to panel I see below status logs :
1. line fault, loop 1
2. Mapping pending, loop1
3. Sensor Initialization ,Loop 1
4. Unprogrammed Trouble ,Loop 1
any one can help me please?
