Fireworks nodes
calebking
Fireworks nodes
Post by calebking »
Hi can anyone help please
I have a site with 3 panels on an A-class network. There are 3 main control rooms where control 1 see's all and can reset all 3 panels whereas the other control rooms can only reset there own panel. I have programmed this from the sdu through the routing control. The problem I have is I'm installing 3 fireworks pc's at each panel but when I import the sdu it imports the 3 cpus as 1 node and so when you go to reset using the fireworksit only sees 1 node which resets all the panels. Is there anyway around this. It's a big job we have and the customer is expecting a lot.
Please help
Calebking
mikbz
Re: Fireworks nodes
Post by mikbz »
did you want restart each panel separatlly or each fireworks station will be reset all panels?
