EST3 Rules-Modcom Contact ID Examples
-- AAAA P CCC XX ZZZ
AAAA - account number,
P - pin status (alarm or restore),
CCC - Contact ID Codes
XX - dialer group, partition or area number
ZZZ - zone or user number.
- PUT THE MODCOM RULES IN THE FRONT, SO IT WILL NOT DELAY BEFORE DIALING OUT
complete list - https://securecs.azsecurity.com/Lists/viewCIDCodes.asp
Contact ID Codes
110 Fire Alarms
111 Fire Alarms SMOKE
112 Fire Alarms COMBUSTION
113 Fire Alarms WATER FLOW
114 Fire Alarms HEAT
115 Fire Alarms PULL STATION
116 Fire Alarms DUCT
117 Fire Alarms FLAME
162 CARBON MONOXIDE DETECTED
200 FIRE SUPERVISORY
201 LOW WATER PRESSURE
202 LOW CO2
203 Fire Supervisory
204 LOW WATER LEVEL
205 PUMP ACTIVATED
206 PUMP FAILURE
210 Supervisory
213 SPRINKLER TROUBLE
300 SYSTEM TROUBLE
301 TRBL-AC
302 TRBL-BAT
[ALARM DIALER BY POINT]
ALARM '*DIALER_<N:1-300:3>':
+Send 'Account_label' MSG "111000<N:3>",
-Send 'Account_label' MSG "311000<N:3>";
If you are using CID you maybe able to just copy/paste these rules
[DIALER FIRST ALARM]
FA :
+SEND 'Account_label' MSG "111000000",
-SEND 'Account_label' MSG "311000000";
[DIALER first TROUBLE]
FT :
+SEND 'Account_label' MSG "130000000",
-SEND 'Account_label' MSG "330000000";
[DIALER first SUPERVISORY]
FS:
+SEND 'Account_label' MSG "120000000",
-SEND 'Account_label' MSG "320000000";
[DIALER LOW BATTERY ]
LTRB '*LO_BAT*' :
+SEND 'Account_label' MSG "130200000",
-SEND 'Account_label' MSG "330200000";
[DIALER TROUBLE BATTERY]
LTRB '*BATT_TRBL*' :
[DIALER GROUND FAULT]
GROUNDFAULT '*' :
+SEND 'Account_label' MSG "131000000",
-SEND 'Account_label' MSG "331000000";
[Phone Line Troubles]
LocalTrouble 'Telephone_Line_<N:1,2>_*' :
+SEND 'Account_label' MSG "135<N>00000",
-SEND 'Account_label' MSG "335<N>00000";
seach words: CID reporting modcom
