hI ALL,
I have a panel , which is Mirtone make Quickstart . I have used EST QS-CU software but it does not communicate.
So , I have replaced CPU ,now its communicating with CPU . But Smoke detectors also is EST-Mirtone Type. So I get trouble for all detectors . Detectors are working fine on smoke test, Hooter are also activated . But it shows traouble afor all the detectors.
Some one Pls Help to sort out this problem.
regards
MIRTONE MODEL QUICKSTART
Re: MIRTONE MODEL QUICKSTART
hi, you need to put back the older cpu an used the mirtone Quickstart software MIRQS-CU.
regards...
regards...
Older Mirtone CPU is fail aow i have to use this QS4 CPU only.
Currently i am getting alarms if testing any detector . But i don get any troubles for open/ short in loop.
mirtone quickstart = Mirtone devices
est quickstart = Est devices
had a Mirtone cpu Panel fail 8 months ago, tried to swap with EST QS CPU, ended up replacing all smoke detectors due to non-compatibility
per EST tech support the smokes are NOT compatible, but the modules are compatible .
