SuperDuct 4-Wire Controller With RTS151
Wiring an EST four-wire superduct controller with a System Sensor RTS151
2 conductor for the duct trip
4 conductor for System Sensor RTS151 test switch
green and red LED will work
rts151
1 red (red LED)
2 black (common )
3 yellow (Test/Reset)
4
5
6 green (green LED)
4-Wire Controller
15 red (red LED)
2 yellow (Test/Reset)
19 green (power/green LED)
20 Black (Common)
https://edwards-signals.com/files/31006 ... ersion.pdf
MODELNUMBERS
TSD-CJ, TSD-CJ24,ESD-CJ, SD-CJ
4-W controller with RJ-45 modular connectors
TSD-SJ, ESD-SJ,SD-SJ
4-W smoke sensor with RJ-45 modular connector
TSD-4WJ, TSD-4WJ24, ESD-4WJ, SD-4WJ
Combination 4-W controller and sensor with RJ-45 modular connectors
TSD-CJG
4-W controller with RJ-45 modular connectors and cover gasket
TSD-SJG
4-W smoke sensor with RJ-45 modular connector and cover gasket
TSD-CT, TSD-CT24,ESD-CT, SD-CT
4-W controller with terminal block connectors
TSD-ST, ESD-ST, SD-ST
4-W smoke sensor with terminal block connector
TSD-SJCO2
4-W sensor with RJ-45 modular connector and TSD-CO2 sensor module
TSD-STCO2
4-W sensor with terminal block connector and TSD-CO2 sensor module
- ----- F i r e -----
- ↳ MANUALS
- ↳ NPFA72/70
- ↳ UTC - EST
- ↳ EST3
- ↳ EST4
- ↳ EST3 Rules
- ↳ I/O panels
- ↳ QuickStart
- ↳ FireWorks
- ↳ EST2
- ↳ Misc/Devices
- ↳ IRC3
- ↳ Notifier
- ↳ ONYXWorks
- ↳ FireLite
- ↳ SilentKnight
- ↳ Ademco - V32FB
- ↳ Fire Alarm Inspection
- ↳ Other FACP
- ↳ Duct Detectors
- ↳ Hardware
- ↳ Honeywell - Winpak
- ↳ honeywellaccess.com
- ↳ HoneyWell - ProWatch
- ↳ HoneyWellIntegrated.com
- ↳ Kantech
- ↳ Readers
- ↳ hidglobal.com
- ↳ Card Access Systems
- ↳ Credentials
- ---- Other Systems ----
- Heliostat
- ↳ Heliostat
- ↳ heliostat.us
