Hi
We have 10 loop EST-3 panel. Which need to integrate with Building management system on BACnet protocol by using FSB-PC.
We need to take only loop status i.e. loop is in alarm or not.
For that can we configure logical group in FSB-PC. So that when logical group is activated then same will reflect on BMS via FSB-PC.
Plz help.
Logical Groups can be define in FSB-PC
Re: Logical Groups can be define in FSB-PC
you can't do like this but you can do it by AND group, for example if you want to show loop devices alarm status then you just add that loop devices into 1st AND group 2nd loop devices into 2nd AND group so on.... and activation count mention 1 then in case of one single device activation that concern AND group will generate alarm active event , By this method you can interface BMS..
Okay but what is the way to configure it in .CSV file for FSB-PC.
If anyone have a sample file please share.
