hello everybody
i got bad type fault for many detectors and when reading the loop it tells me this is due to detector base changed but the base is same no change !!!!
bad type due to detector base
Re: bad type due to detector base
this does happen sometimes
how many times did you upload the map?
is there a map fault, if so may need to fix it first
