FSB-PC2 communication from EST-3 to BMS
donpccc
Contact:
Post by donpccc »
Hi all BRO,
Recently, we have some projects using FSB-PC2 to connection BMS base on Bacnet-IP Protocol.
Before ago, we used to FSB-PC and configure via Ruinet tool . And now, with FSB-PC2 we can direct access and configure via web services. It's very easy to configure, show status and do anything like as configure switch or internet moderm.
But now, i must change FSB-PC (old version) to FSB-PC2 therefore i still used config.csv in olde one to download the new FSB-PC2.
With FSB-PC, this configure is correct and the FSB-PC connected to EST-3 control panel very good and BMS also see Fire alarm system.
But now i download this config.csv to FSB-PC2, the result:
1. BMS still see the FSB-PC nodes
2. But FSB-PC2 can not read EST-3 points (I make sure the physical is good, wiring is good). I think may be must to change something driver for this new version. If someone already did this, please help me some advices for resole it!
Thank You,
Don Nguyen
donpccc
Contact:
Re: FSB-PC2 communication from EST-3 to BMS
Post by donpccc »
donpccc wrote:Hi all BRO,
Thank You,
Don Nguyen
Any one, get out of problem!!!
donpccc
Contact:
Post by donpccc »
Thank You,
Don Nguyen
After reading carefully the documents, the error is fixed.
Only need to change 2 command line!
.... Thank the god
ali.hps2002
Post by ali.hps2002 »
I am using Modbus TCP protocol for BMS configuration, I am getting signals from FSBPC2 to Modscan for every device except SIGA-CT1
What could be the reason?? Can someone help me out.
