FIREWORKS COMMUNICATION ISSUE
emeen
Post by emeen »
When i try to connect the fireworks pc with EST3 Panel, am getting Ground fault and communication is not established. But when i connect my laptop its working fine. Any suggestions please.
Re: FIREWORKS COMMUNICATION ISSUE
broke the ground lug off the pc's power cord
emeen
Post by emeen »
Thanks i have tried but still remains same. once i connect the communication cable from pc to RS232 Card even with out powering the pc . i am getting ground fault.
junjun
Post by junjun »
then try another pc.
ennab1977
Post by ennab1977 »
There’s a small DIOD or suppressor diod between the ground of the communication and the earth take it out with solder or heat gun but check which one by using a multimeter
