Simplex 4005
Re: Simplex 4005
The simplex CCDACT used with the 4005 is programmed separately from the main panel using any terminal emulation software such as Hyperterminal. I have the programming manual if you need it. You will need a Simplex programming cable though. I have the pin out for that. It can only send 4+2 or 3/1 formats. It may be easier to simply disable the internal dialer and install an external of your liking. You can disable it through the keypad. The default programming passcode is 4000. If this has been changed and you don't know what it is, you will not be able to disable the dialer.
Simplex 4005
Can the DACT card be programmed from the front panel or do you need the software, witch only simplex has.
