Hi Friends,
Does Anyone having previous experience in the field of cement factory (fire detection system),
if yes could you help me to select correct fire detector type for those factory, because we cant use normal photo electric type smoke detectors because it will make false alarms, so please help me ...
Fire Detector for cement factory
Re: Fire Detector for cement factory
Hi friends below mentioned areas has to protect
Locations
Security Office & Access Control Area
31
MCC Room - Raw Mill 1
2
Changing Rooms
32
MCC Room - Raw Mill 2
3
Medical Center
33
MCC Room - Waste Gas
4
Training Center & Labs
34
MCC Room - Shredder
5
Logistics Office - Old
35
MCC Room - Crusher 1
6
Logistics Office - New
36
MCC Room - Crusher 2
7
Main Stores & Office Area
37
MCC Room - Oil Unloading
8
Main Stores - Fuel Storage
38
MCC Room - Solar Drying
9
Packing Plant 1
39
3.3 kV & 415 V Sub
10
Packing Plant 2
40
3.3 kV Sub - Switch Gear & Transformer Room
11
Procurement & Maintenance Office
41
33kV Sub - GIS
12
Mechanical Workshop
42
MCC Room - Algae
13
LSRT Office
43
MCC Room & VFD Room - Coal Mill
14
Projects Office
44
VFD & Transformer - PH2 3rd floor
15
Management Building
45
VFD - PH2 5th floor
16
Canteen
46
Compressor Room - Near Cooler
17
HR / Admin / Finance Office
47
Compressor Room - Kiln
18
Pump House
48
Compressor Room - Raw Mill
19
CCR & Office Area
49
Voma Pump Room
20
Roller Press Area
50
Kiln 1 - Burner
21
Pre Heater 1
51
Kiln 2 - Burner
22
Pre Heater 2
52
Shredder building
23
Coal Mill Area
53
Backend Storage Room
24
Raw Mill Control room
54
Day Tank Area
25
MCC Room - PP1
55
Geocycle Containers - Office & Lab
26
MCC Room - PP2
56
Backend Feeding Area
27
MCC Room - RP
57
Solar Drying Area
28
MCC Room - CM
58
Rubber Preprocessing Area
29
MCC Room - Cooler
59
AFR Weigh Feeders
30
MCC Room - Kiln
60
Locations
31
2
Changing Rooms
32
3
Medical Center
33
4
34
MCC Room - Shredder
5
35
6
36
7
37
8
38
9
Packing Plant 1
39
3.3 kV & 415 V Sub
10
Packing Plant 2
40
11
41
33kV Sub - GIS
12
Mechanical Workshop
42
MCC Room - Algae
13
LSRT Office
43
14
Projects Office
44
15
Management Building
45
VFD - PH2 5th floor
16
Canteen
46
17
47
18
Pump House
48
19
CCR & Office Area
49
Voma Pump Room
20
Roller Press Area
50
Kiln 1 - Burner
21
Pre Heater 1
51
Kiln 2 - Burner
22
Pre Heater 2
52
Shredder building
23
Coal Mill Area
53
24
54
Day Tank Area
25
MCC Room - PP1
55
26
MCC Room - PP2
56
27
MCC Room - RP
57
Solar Drying Area
28
MCC Room - CM
58
29
MCC Room - Cooler
59
AFR Weigh Feeders
30
MCC Room - Kiln
60
Last one I did we used linear heat detection.
