est-2 relays latch after reset
raydaviesjr
Post by raydaviesjr »
did anyone have relays not restore after panel alarm for fan/doors
Re: est-2 relays latch after reset
how is it turn on when an alarm is activated, Common Alarm output or rules
if the output device is a Common Alarm output I am thinking it should just follow the alarm.
raydaviesjr
some are programed as doorcontrol/and fancontrol i have several panels
after alarm some releys wont reset.when i check status they are still active. the only way is to restart cpu
i have tryed several other ways
can you program the outputs as "Common Alarm output" this way the outputs will follow the panels alarm with no programming.
if you want I could look at it, if so pm me
