need help on 2 panel. map error, autocnfig, internal mem
notoriousfox
Post by notoriousfox »
Hello all,
I recently rebuilt the database on a 2 panel. After downloading I keep getting the same faults. Internal Memory Fault, Mapping Error, Autoconfigure fault.
I can not get them to go away. My map is clean. I pulled it, accepted all, relabeled, wrote new rules, everything looks good. I can't figure out why I keep getting these faults.
any help would be appreciated.
pyrosucks
Re: need help on 2 panel. map error, autocnfig, internal me
Post by pyrosucks »
Check project parameters to ensure the correct mcm version is chosen.
notoriousfox
Thanks. Going back to site tomorrow. Will look at the parameters and see if I fudged up the mcm version.
old_tech
Post by old_tech »
Most likely you have a bad 2-MCM (or 2-lcx). Sometimes a bad device will cause an internal error. If you remove the data loop wire and download a test program with nothing in it and still see the error, you know for sure.
