Facility Commander
AKA-Casi Rusco, Software-Facility Commander panel-M5/M3000, Cards-PXNplus, 8RP
Eagle00708
Facility Commander
Post by Eagle00708 »
I have a facility that is running Facility Commander 7.7. The customer wanted to add a button to lock all doors acroos 15 different controllers. We are using output groups and set up an alarm. When tested the doors, all of them lock and then unlock. I have had tech support look into it, they are testing some stuff on the bench but I'm just looking for some outside input.
Re: Facility Commander
I do not work with FC any more, but 2/3 years ago when I did I was dealing with this same thing.
it worked the only problem was that after the lock down was turned off (the input want normal) no-admin card holders were still not able to get in. the panels needed to be download to fix the problem.
I think also I had the inputs reversed, when the input was normal the school was in lock down.
