New EST4 panel
Posted: Mon Sep 23, 2019 7:57 am
**** it is about time *****
Programming - Configuration data travels in both directions: it can be downloaded to the panel and uploaded to a laptop. This two-way movement of configuration files allows technicians to upload and backup programming before making changes to the system.
Also, should the building owner change service companies,
up-to-date system programming data can be retrieved with proper
authorization, from the panel by the new maintenance personnel
in minutes.
Adding to the integrity of panel configuration is an advanced data
transfer routine that does not compromise or interrupt normal
system operation. This keeps the system fully functional during
configuration data exchange
EST4’s high-performance Configuration Utility (CU) depicts the
system in a graphical tree view, which matches the system’s
physical layout. This provides a familiar format in which to find
programming for specific devices, and also does away with the
need for look-up lists when, for example, devices need to be taken
out of service because of site specific activities. The programming
tool also features a context-sensitive Intellisense rule editor, which
checks for syntax and semantic programming errors in real time.
The EST4 Configuration Utility (CU) also makes short work of
configuration downloads to the control panel. It does this through
a single firmware download for all modules, and a single database
download for all node databases.
EST4’s on-board USB ports also make it easy to connect with
external devices. The USB ports do away with special cables
and RS232-to-USB conversion dongles. It allows direct highspeed connection with laptops for the exchange of configuration
data at transfer rates of up to 480 Mbps.
https://myeddie.edwardsutcfs.com/Media/ ... erview.pdf
https://www.edwardsfiresafety.com/Home/EST4
https://www.edwardsfiresafety.com/Lifel ... 20Platform
in minutes.
