**** it is about time *****
Programming - Configuration data travels in both directions: it can be downloaded to the panel and uploaded to a laptop. This two-way movement of configuration files allows technicians to upload and backup programming before making changes to the system.
Also, should the building owner change service companies,
up-to-date system programming data can be retrieved with proper
authorization, from the panel by the new maintenance personnel
in minutes.
Adding to the integrity of panel configuration is an advanced data
transfer routine that does not compromise or interrupt normal
system operation. This keeps the system fully functional during
configuration data exchange
EST4’s high-performance Configuration Utility (CU) depicts the
system in a graphical tree view, which matches the system’s
physical layout. This provides a familiar format in which to find
programming for specific devices, and also does away with the
need for look-up lists when, for example, devices need to be taken
out of service because of site specific activities. The programming
tool also features a context-sensitive Intellisense rule editor, which
checks for syntax and semantic programming errors in real time.
The EST4 Configuration Utility (CU) also makes short work of
configuration downloads to the control panel. It does this through
a single firmware download for all modules, and a single database
download for all node databases.
EST4’s on-board USB ports also make it easy to connect with
external devices. The USB ports do away with special cables
and RS232-to-USB conversion dongles. It allows direct highspeed connection with laptops for the exchange of configuration
data at transfer rates of up to 480 Mbps.
https://myeddie.edwardsutcfs.com/Media/ ... erview.pdf
https://www.edwardsfiresafety.com/Home/EST4
https://www.edwardsfiresafety.com/Lifel ... 20Platform
New EST4 panel
Re: New EST3 SDU
Are you looking for it or you have it ? i have 5.4 and 5.42 looking for latestest.
Re: New EST4 panel
Hello Leo, do you have software for programming new EST-4.
Thank You.
Thank You.
Re: New EST4 panel
est4 cu does not use a hasp key, its a whole different system, i took the class and this is gonna be the cadillac of fire alarm soon
- Contact:
Re: New EST4 panel
Dear Bro,SUPERTECH wrote:est4 cu does not use a hasp key, its a whole different system, i took the class and this is gonna be the cadillac of fire alarm soon
Thank for your information. Do you have use WhatsApp?
Can you share with me the software use for Est4 panel.
The software run no need hasp key or need license?
How to do get license for it?
Thank,
Henry Nguyen
Re: New EST4 panel
UTC say the new dongle insert to the CPU when download / upload
Re: New EST4 panel
Hi
Anybody... have 4-CU setup file for shared ?? Send pm please..
Re: New EST4 panel
if you install the software,it will be a demo. you need to be certified in order to receive a key from edwards
Re: New EST4 panel
Hi bro..SUPERTECH wrote:if you install the software,it will be a demo. you need to be certified in order to receive a key from edwards
I know it.... only want run in demo mode for review features.
if do you have..then send me link for download demo, please and thanks.
regards
Re: New EST4 panel
will be what anybody have a setup files 4-VCU for est4 panel??
for share with me, without key nothing license, only for use demo mode
if there are, please send link for download at my p.m.
thanks
regards
thanks
regards
