i need to buy the dongle for EST3
engbaddaly
Post by engbaddaly »
dears all,
kindly, i need to buy the dongle key for est3 because i lost my one.
fa3
Post by fa3 »
Dear lts-maroc;
I will appreciate if you send to my email(omid_raha7@yahoo.com) "https://rapidshare.com/#!download|434p1 ... up2012.zip"
Best Regards
juanjose
Re: i need to buy the dongle for EST3
Post by juanjose »
DEAR ENGBADDALY:
THIS HASPKEY WORTHS 500 DOLLARS BUT YOU NEED TO CONTACT YOUR UTC PROVIDER TO GET ONE, FIRST OF ALL YOU HAVE TO PROVE YOU ARE CERTIFIED, IF YOU GOT YOUR HASPKEY WORKING FOR A THIRD COMPANY YOU NEED TO ASK THE IF THEY CAN GET A NEW ONE FOR YOU IS CHEAPER, IF NOT YOU NEED TO RECERTIFY, I HAVE LOST MINE TOO, AND I WASY NOT ABLE TO BUY A NEW ONE, I HAVE TAKEN A RECERTIFICATION COURSE AGAIN IN MEXICO, TO GET A NEW ONE, TOTAL SPENT 3500 DOLLARS.
lts-maroc
Post by lts-maroc »
Dear Friends,
I have a solution for you, to avoid any lose of your HASP key, you can dump the key with dongle services, or get a cracked software that can dump it and emulate it when you don't need to use the dongle key.
I leave the company that i worked for, and i use it for my own projects, for maintenances.
Good Luck.
Yassine
lts-maroc
Post by lts-maroc »
These File i will join to you contains the file cracked, but need hat you follow these instructions, it works as EST3 Software Key:
1- i tested with XP system
2- Return the date of the system to a Valid from 26/Aug/2010 to 2/Sep/2010, you choose one date .
3- Open the "USB Dongle Backup and Recovery 2012", go the the tab "Driver", then "Install Driver", verify in this tab, in "Driver Statuts "that the driver is installed.
4- Go to the "Emulator" Tab then "Start Service", wait untill it started.
5- Load dump, witch is "1A4B27EB.dng".
6-run your application.
7-Enjoy.
If you want to install a new application of 3-SDU, you have just to repeat from 1---5 , then nstall the application, the PIN code is "EDF5856EEF3CEB93" , please the date is so important to change it before start the operation.
Please go to these URL to download the files: https://rapidshare.com/files/3728587953/1A4B27EB.dng
https://rapidshare.com/files/381519616/ ... up2012.zip
Enjoy.
The download files are not found.
could you email them to me - leogerst@hotmail.com
lts-maroc
Post by lts-maroc »
Dear leo,
you're right the file isn't found, so the new link is : https://rapidshare.com/#!download|434p1 ... p|2145|0|0
alpha bravo
Post by alpha bravo »
I keep getting all sorts of warnings from my system.
Has anyone tried this thing?
FVILLA
Post by FVILLA »
alpha bravo wrote:I keep getting all sorts of warnings from my system.
hi the trouble starts when you change the date in your system, i recommend to install a virtual machine to run this emulator.
the files and emulator is 100% safe but some antivirus may popup a warning.
regards...
lts-maroc
Post by lts-maroc »
i tested this solution in my computer before share it, and it works very perfectly, and i download/upload from panel.
Please Send me your error messages then will see what i can do.
Regards
