I can connect fine using the NUP but when trying to use the USB connector with Verifier I get a ground fault.
Does someone have the same experience? If you did, where you ab to fix it and how?
Ground fault when connecting Verifier by USB to Notifier-3030
Re: Ground fault when connecting Verifier by USB to Notifier-3030
rondparker wrote: ↑Fri Feb 19, 2021 6:34 pm I can connect fine using the NUP but when trying to use the USB connector with Verifier I get a ground fault.
Hi, that is normal, when you unplug the USB cable from the panel the ground fault must go
Beautiful. Thanks for your help
Utilize a three prong to a two prong AC plug adapter to plug in your computer.
