IO-CU IO64 IO500 software download
Download
IO-CU_Setup_3.5
IO-CU_Setup._3.4
IO-CU_Setup4.0
IO-CU_Setup4.1
FSA-CU Version 3.5 and Firmware Version 2.3 Release Notes
https://www.edwards-signals.com/index.c ... l=25&sid=0
remember:
WHEN YOU INSTALL AND RUN FOR THE FIRST TIME, YOU CREATE YOUR OWN PASSWORD
search words:
EST io64 software
IO500 IO1000
I/O 3.5 software
I need IO-CU ver 3.5
rmorasse
Re: IO-CU IO1000 software download
Post by rmorasse »
Any one have IO-CU 4.4
vectrasoundz
Re: IO-CU IO64 IO500 software download
Post by vectrasoundz »
Hi, any chance you have 4.1?
AZFIREGUY
Post by AZFIREGUY »
Does anyone have 4.11 IO-CU software available?
APEN
Post by APEN »
Hello does any one know what is the latest panel version for iOS 500. I’m getting a 5003 error code when trying to write to the panel, only then I can read from panel just fine but not write. I’m using io-cu 3.1 any help much appreciated
isatronix
Post by isatronix »
hi
the latest version is 4.2 for IO-CU and VS-CU
the version of slc loop card are incompatible,
if your version data base panel is you need upgrade
Version 4.2 firmware compatibility
Panel firmware version 4.2 is not compatible with iO-CU 3.0, 3.1, 3.2, 3.31, 3.32, 3.4, 3.5, 4.0,
4.1or 4.11. If you have a panel with version 4.2 firmware, iO-CU version 4.2 or later is required.
Version 4.2 firmware is not compatible with old loop (SLC) cards. Your panel must have the
iO-SDC1 or iO-SDC2 SLC interface cards installed.
regards
Overreved
Post by Overreved »
I cant seem to openm the IO software because its a xxx file anyone run into this.
Protecse
Post by Protecse »
Hola
ME PUEDEN APOYAR CON EL SOFTWARE PARA PROGRAMAR EL PANEL iO1000
srcontres@gmail.com
Protecse
Post by Protecse »
Necesito IO-CU ver 3.5
FVILLA
Post by FVILLA »
Protecse wrote: Thu Nov 18, 2021 7:41 pm Necesito IO-CU ver 3.5
http://www.thealarmtech.com/download/ES ... up_3.5.zip
