Installing Telguard TG7 - Introductory Class 101
Posted: Fri Jan 06, 2017 7:29 pm
Basics and Advance installation of the TG7
https://www.telguardonline.com/
http://www.thealarmtech.com/manuals/Tel ... nstall.pdf
**** important ****
Sending Signals from Telguard to your CS via an internet connection:
You may have noticed that the signals sent from a Telguard to your CS are delay by sometimes 20 minutes,
THIS IS A JOKE and when I say joke I mean a complete embarrassment.
If your CS has a receiver that can get signals from Telguard via the internet the signal is received by your CS in seconds.
CID is the only format that can use an internet connection
4/2, SIA can only dial into your receiver.
Pulse or Rotary
Most if not all phone lines do NOT work on ROTARY anymore.
when you have a control that fails to get out vs pulse a few times it may go to rotary and stay there, ever if the lines restore the control will not.
I have seen these a few times with the v32fb panel.
Good news the TG7 will work with Rotary
10 Digit dial only
When programming FACP make sure the Receiver phone numbers are 10 Digits or the TG7 will not work.
Note: 555-5555 will not work.
The TG7 is active when the top green LED is on.
The first Signal that is sent from your FACP will activate the TG7.
Note: The first signal is not sent to the CS, only to Telguard
RJ45 Splitter for Connecting both primary and secondary phone jacks to Telguard's one jack.
https://cdn.adiglobal.us/CatalogImages/ ... SPLT-1.jpg
Fire-Lite Model #: IPSPLT
* great little device
PROGRAMMING for 4/2 format - supv the comm fail
Link Supervision
Supervision Restoral Code - 1414
Supervision Fail Code - 1515
when the telguard link fails a "FF" will go to your CS
when the telguard link restores a "EE" will go to your CS
let your CS know the fail/restore codes
PROGRAMMING
Registering a new TG7
Tab: Subscriber & Units -> Register Subscriber
Installing Telguard TG7 as "Mode of Operation" Cellular only
Tab: Link Supervision - Sole Path Fire (60 minutes) NFPA 2013
Tab: Link Supervision - Sole Path Fire (5 minutes) NFPA 2010
Yellow LED 5 Flashing - Link supervision Enable (2 flashes every 6 seconds)
Note: if LED 5 is not flashing Link supv is not enable.
LEDS for Cellular only : top green on, bottom red power on and LED 5 flashing.
Setting the Account and Receiver phone numbers
Tab: Central Station Info -> Alarm Panel CC
The TG7 will use the FACP's account and receiver numbers.
Tab: Central Station Info -> TCC (Telular Comm Center)
The TG7 will use the account and receiver numbers enter in the below fields.
Note: only use when "Mode of Operation" is Cellular only.
When TG7 uses phone lines it sends FACP's account and receiver numbers.
Re: Installing Telguard TG7 - Introductory Class 101
Posted: Sun Jan 08, 2017 11:14 pm
by Kmaysob
If you get a chance, try out the dsc 3g4070cf. Ul listed to be a stand alone communicator. Thats all we install anymore
