inspection report (pass/fail)
Posted: Tue Feb 07, 2012 10:43 am
Did the inspection of the fire alarm pass or fail.
seems like an easy enough question to answer.
NFPA72 does not have a places on the form to check. This Fire Alarm System pass/failed its inspection. Why not?
If you look at alarm companies that made their own inspection report forms some will put a pass/fail of some kind on it and it looks like they are just failing things to drum up business.
The city of Philadelphia has their own inspection form and it is one the best. The form breaks the inspection down into 7 sections that on the first page of the form require you to answer YES or No (pass or fail). Their also use two words Acceptable and satisfactory, which buts the responsibility on the inspector in a good way.
You may want to fail an inspection because it is an old panel with one smoke and one phone line. This more then likely was ok with the AHJ at the time it was installed. So are you going to fail it or pass it?
The question I am asking is how do you deal with the pass/fail of an inspection.
