Hi All,
Im using 3-SDU Ver 5.02.Im trying upload evac message in ASU but its not responding.pls help me how to rectify.
Thanks,
Hi all I have problem to uploade data on 3-ASU
Re: Hi all I have problem to uploade data on 3-ASU
I am not familiar with your version of SDU but below is some information:
Adding custom messages to the 3-ASU database expands the capabilities of the Emergency Voice/Alarm Communication System. The SDU automatically creates four message records when the 3-ASU is added to the cabinet configuration table; a default normal message, alert message, evacuation message, and preannounce message.
Note: The number of custom messages that a 3-ASU can store depends on the run length of all the messages added together and the amount of memory installed on the 3-ASU. A single message may not be longer than 40 seconds.
Tip: Enter the text of the audio message as the object's message to use as a script when recording the message content.
To add a custom message to the 3-ASU database:
On the Configure menu, choose Cabinet.
Select the cabinet that contains the 3-ASU being configured and then click the Modules tab.
On the Hardware Layer tab, select the 3-ASU, and then click LRM Config.
Click the Messages tab, then click Add.
Click the Message Label cell for each new record in the message table and enter a label.
After you have finished creating message records, click the OK, and then click Close.
Using the Audio tool, record the message content for each of the messages.
I also found in a manual that the audio message data for 3-ASU operations may be directly downloaded into the ASU VIA J1 in the single step mode or over the network via j5 on the CPU in the networks communication mode.
