AND GROUP
hijazih
AND GROUP
Post by hijazih »
Hi All,
I want to activate my outputs using a combination of avtivated detector and a switch on the Panel. Any clue ??
Thks
Squidmonkey
Re: AND GROUP
Post by Squidmonkey »
Hello,
Can you use the switch to simply enable the and group?
if not, if you use
sw 'switches_name' : activate 'and_group';
It will increase the and group counter by one, thus getting it one step closer to the activation number.
Hope this helps.
hijazih
Re: AND GROUP
Post by hijazih »
This Configuration will also activates the outputs if 2 detectors are activated regardless the activation of the switch.
