Ground Fault on Panel
Posted: Sun Apr 24, 2011 5:07 pm
by ggkinuthia
What causes ground fault even when all the field connections are disconnected from the control panel?
The power supply grounding is properly done..
Re: Ground Fault on Panel
Posted: Mon Apr 25, 2011 7:22 am
by junjun
have you remove 24v auxillary outputs, network connection, rs232 connection, firetelephone riser output, etc? and still you have groundfault on your panel?
Posted: Mon Apr 25, 2011 9:04 am
by ggkinuthia
I did remove all the modules and the ground fault disappeared. But when I connect any of the two Amplifiers(ZA-40/70) in a cab7 panel the ground re-appears. I now guess its the Amp that are causing this ground fault
