Ground Fault on Panel
ggkinuthia
Post by ggkinuthia »
What causes ground fault even when all the field connections are disconnected from the control panel?
The power supply grounding is properly done..
junjun
Re: Ground Fault on Panel
Post by junjun »
have you remove 24v auxillary outputs, network connection, rs232 connection, firetelephone riser output, etc? and still you have groundfault on your panel?
ggkinuthia
I did remove all the modules and the ground fault disappeared. But when I connect any of the two Amplifiers(ZA-40/70) in a cab7 panel the ground re-appears. I now guess its the Amp that are causing this ground fault
