EST3-pseudo point 0600 - Annunciator Supervision
Posted: Sat Jun 26, 2010 3:33 pm
pseudo point 0600 indicates a problem with LED or switch module, check the ribbon between the switch module on board.
IE: Point 01000600 - panel 1, slot 0, pseudo 600
- This would be a problem with the main display to panel 1's CPU.
IE: Point 01020600 - panel 1, slot 2, pseudo 600
- This is the annunciator supervision of a LED or switch module that is mounted on the PPS/M module. if the Power supply was replace just check to make sure the annunciator ribbon cable was re-connected properly.
The problem I had was after replacing the PPS/M module I connected the switch ribbon back on to the PPS/M module, but it was not connected before I replaced it. So the Pseudo point 01020600 came in.
search: EST3-pseudo point 0600 - Annunciator Supervision
