** EST3 - Mapping Faults
EST3 - Mapping Faults, EST3's biggest problem
The EST3 system is a good fire panel, but the biggest problem fire alarm technicians have is fixing Mapping Faults.
** EST3-MAP - Commit Expected - changing devices out - http://www.thealarmtech.com/forum/viewt ... ?f=5&t=326
SSDC1 ver 3.6,downloaded with SDU 3.7 and not mapping - http://www.thealarmtech.com/forum/viewt ... ?f=5&t=428
EST3 - 3-SDU V3.72 will not map - http://www.thealarmtech.com/forum/viewt ... ?f=5&t=402
EST3-MAP - Balanced Map, what is it - http://www.thealarmtech.com/forum/viewt ... ?f=5&t=190
Re: ** EST3 - Mapping Faults
When to initialize the map card
If all looks good and you can not find any problems (JUST INITIALIZE THE CARD)and then load the ssdc/sddc card.
icyangle
Post by icyangle »
Basically speaking,mapping faults always happen when your line is not good,and the EST3 equipment is not running very well.
get a SIGA-MFT, it diagnoses the loop then tells you what to check/replace. it's for any of the est systems with signature devices
