EST3-CPU CODE
esmaeel
EST3-CPU CODE
Post by esmaeel »
hi all.
whats the cpu code?
how can i use that?
thanks
FVILLA
Re: CPU CODE
Post by FVILLA »
hi, hope this is what your looking for.
regards...
EST3 - 3-CPU3 Boot Code Version
Introduction
New 3-CPU3 modules are being shipped from the factory with application and boot
code version 3.70. This may result in a 3-SDU mismatch message.
Issue
3-SDU version 3.72 includes only 3-CPU3 boot code version 3.60. Version 3.70 is not
available. This causes a mismatch message.
Solution
There is no functional difference between the 3-CPU3 version 3.60 and 3.70 boot
code. You have two options.
First, you can simply ignore the mismatch message.
Second, you can go to http://www.est.net, log on, and download the 3-CPU3 version 3.70
boot code. Then, using the Tools > Import Microcode command, import the
downloaded version 3.70 boot code into your 3-SDU (3-SDU versions 3.70, 3.71, or
3.72). This resolves the mismatch. No downloads to the panels are needed.
