EST-3 SDU Version 5.32 not uploading SSDC-1 card
Posted: Tue Jun 04, 2019 12:47 pm
by deavilaa
Hello, I have an EST-3 panel with three SSDC-1 loop cards. I recently had to change out a module on one of the loops. The panel would not map it in automatically, so I decided to upload the loops on each SSDC-1. Well, the first two did upload correctly, but the last one did not upload at all. It basically came back with no devices attached to it. I changed out the SSDC-1 and it did the same thing. Can anyone assist with this?
Re: EST-3 SDU Version 5.32 not uploading SSDC-1 card
Posted: Fri Jun 07, 2019 7:10 pm
when I change a device I will change the device and wait to see if it maps.
if not
remove the device, change the serial number in the SDU
WAY WAY WAY Easier,
you are asking for trouble if you leave it on the SLC and upload it.
The map is blank because it is not done mapping.
via the SDU program watch it map, under status
if it never completes mapping, keeps starting over you got a problem
sometimes the smoke is not in the base tight
and if you are unlucky,
for an EST tech this is when the rubber hits the road
Posted: Sat Jun 08, 2019 5:21 pm
by isatronix
Connect the programmer cable in rj connector of slc card, if you connect in cpu card then only upload the slc card atached
regards
Posted: Mon Jun 10, 2019 7:51 am
by deavilaa
Thanks! After some more troubleshooting, I got it to map and life is good!
