Fetching 3SDU Log File
killer88
Post by killer88 »
Please can anyone help me on how do i get a log file in sdu for a project , like when anything changed , when a sdc card was initialized ?
Re: Fetching 3SDU Log File
Any thing changed? A label for an amp? A change to a rule to include another floor? bad devices swapped out?
sdu reports only show what the current configuration is and what what it does. You could try to compare two versions of the same project, but good luck with that.
The building reports file doesn't even include system sensor devices. So good luck counting heads if you have older equipment still in service.
Initialized cards show up in panel history, but panel restarts cause similar events.
one programmer per site is the only way to track anything unless everyone logs specifically what they did.
