I do not think so.
a unprogrammed device is not in the program that was loaded to the panel.
so even if you could give it a address it would still be unprogrammed.
Using SIGA_PRO To Changing Detector
Re: Using SIGA_PRO To Changing Detector
Hi Zeroo,
if the loop mapping is complete, remove the faulty detector, wait for aprox. 3 min. then install the new detector, wait for few minutes then the unprogrammed trouble will be restored.
if you have more than 1 detector, do this whole process for the first then try the second and so on....
Please give me your feedback
Hi Engineers,
I Have Small Problem in One Project ,We Need To Change Some Faulty Detectors
MY Question :We Can changing This Detectors By Adjusted The Address By SIGA_PRO Without to give Us UnProgrammed Device Trouble ,
If We Can What The Standard Procedure ?
