Hi all BRO,
Recently, we have some projects using FSB-PC2 to connection BMS base on Bacnet-IP Protocol.
Before ago, we used to FSB-PC and configure via Ruinet tool . And now, with FSB-PC2 we can direct access and configure via web services. It's very easy to configure, show status and do anything like as configure switch or internet moderm.
But now, i must change FSB-PC (old version) to FSB-PC2 therefore i still used config.csv in olde one to download the new FSB-PC2.
With FSB-PC, this configure is correct and the FSB-PC connected to EST-3 control panel very good and BMS also see Fire alarm system.
But now i download this config.csv to FSB-PC2, the result:
1. BMS still see the FSB-PC nodes
2. But FSB-PC2 can not read EST-3 points (I make sure the physical is good, wiring is good). I think may be must to change something driver for this new version. If someone already did this, please help me some advices for resole it!
Thank You,
Don Nguyen
FSB-PC2 communication from EST-3 to BMS
Re: FSB-PC2 communication from EST-3 to BMS
Any one, get out of problem!!!donpccc wrote:Hi all BRO,
Thank You,
Don Nguyen
After reading carefully the documents, the error is fixed.donpccc wrote:Any one, get out of problem!!!donpccc wrote:Hi all BRO,
Thank You,
Don Nguyen
Only need to change 2 command line!
.... Thank the god
I am using Modbus TCP protocol for BMS configuration, I am getting signals from FSBPC2 to Modscan for every device except SIGA-CT1
What could be the reason?? Can someone help me out.
