Data Card Fault Two
b.n.f
Data Card Fault Two
Post by b.n.f »
hi
i have problem with my est3 panel
i have one sddc1 (with two loop) that i dont use one of the loop circuit(#2) and now i have a fault on lcd contain : Data Card Fault Two
any solution?
MartinTong
Re: Data Card Fault Two
Post by MartinTong »
try unplug the small card and plug again
b.n.f
Post by b.n.f »
hi martin!
i try this(unplug the small card and plug again) but doesnt work and lcd display this fault again! do you have any solution else?
MartinTong
b.n.f wrote:hi martin!
This means the small card was damage, your loop card is SSDC1 or SDDC1 ?
b.n.f
Post by b.n.f »
hi again dear martin
it is sddc1
b.n.f
Post by b.n.f »
martin there is some thing that i think the small card was not damage , when i program the sddc1 card in sdu software i dont active the loop mapping in data card two and so there is a fault on lcd that mappin disable in data card two , as i active the mapping in data card two there no trouble on lcd!
is it possible because there is no device on datacard2 lcd goes to this trouble?
MartinTong
b.n.f wrote:martin there is some thing that i think the small card was not damage , when i program the sddc1 card in sdu software i dont active the loop mapping in data card two and so there is a fault on lcd that mappin disable in data card two , as i active the mapping in data card two there no trouble on lcd!
try card 1 and card 2 exchange ,
briac
Post by briac »
if there is nothing on the datacard2 desable the mapping on this card and make it class B then make F7 ,F9.
