DEVICE TYPE FOR CC1 (SOUNDER & FLASHER)
Maw Kuri
Post by Maw Kuri »
PROBLEM: I tried several device types' for the CC1 serving a sounder & flasher to accommodate the client's requirement that when an assigned switch on the Firemans Panel is pressed would mimic a fire scenario. The rule was just copied from a fire scenario on Zone 01, but the input event which is 'smoke alarm' was replaced with 'SW event''. When the smoke alarm in Zone 01 is active all the outputs works just fine including the sounder and flasher. But when the fire in Zone 01 is initiated by a 'SW', all other outputs would work except the sounder and flasher. Any suggestion please.
old_tech
Re: DEVICE TYPE FOR CC1 (SOUNDER & FLASHER)
Post by old_tech »
Create an AND then activate it with the switch
Maw Kuri
Post by Maw Kuri »
Thank you
