EST3 to BMS Communications Bridge
avish
Post by avish »
Hi All
I am in desperate need of assistance to set up the BACnet IP configuration for the EST to BMS communications bridge. I have gone through several different configurations but don't seem to be getting any closer to success.
I have attached the gateway export of the logical addresses from the SDU (points required highlighted) and the default config from the bridge. Any assistance would be greatly appreciated.
08-10-2017_BMS_DefaultConfig.csv
(19.27 KiB) Downloaded 479 times
07-10-2017 FNB_DC2.CSV
(6.34 KiB) Downloaded 498 times
Nirujan
Re: EST3 to BMS Communications Bridge
Post by Nirujan »
HI could you attach your sdu file I will work out and give you.
