Hi junjun,
how can i add the points to the sample file you attached. I've already attached a sample of ligical addresses.
please advise
EST3 to BMS Communications Bridge FSB-PC
Re: EST3 to BMS Communications Bridge FSB-PC
The sample that i attached are taken from your logical address, you'll just going to edit those having ? Mark because i dont get the personality of your module. And if its still confusing for you just send me all the points to be monitored including their personality(alarm,supervisory,monitor).
Hi MR.junjun,
We also using FSB-PC for connection EST-3 to BMS via bacnet-IP. The BMS person using Bacnet IP explore to show the Object points.
Last time i using the sample configure from the Man in Singapore. But the BMS can not see any thing.
Now i using your sample configure, the BMS side can see the Note: Virtual_BCU_11 with instance number 18201.
And in sumary see 31 points, but can not see detail inside.
We're very happy to more detail contact with you for resole this problem.
My email: donpccc@gmail.com,
Thank you,
Don Nguyen
Thank you,
Don Nguyen
junjun wrote:The sample that i attached are taken from your logical address, you'll just going to edit those having ? Mark because i dont get the personality of your module. And if its still confusing for you just send me all the points to be monitored including their personality(alarm,supervisory,monitor).
Hi MR.junjun,
Thank you,
Don Nguyen
can anyone help me to teach me configure bacnet..i dont understand..please help me urgent....
Hi Junjun
Can I get same sample.csv for FSB-PC2 (Modbus TCP/IP to Siemen Profinet)
