Hello,
I've been testing the Skcheck.exe tool with my hasp key connected in Windows XP SP2 and SP3 without any problems. Here's the result:
Key Existance Test: Passed
Key Status Test : Passed
Key Code Test : Passed
Serial Number : 000908
3-SDU : Enabled
> Delete Project
> Save Project
> Import Project
> Export Project
> Compile Project
> Download Project
> Import MicroCode
> Audio
2-SDU : Enabled
> Delete Project
> Save Project
> Import Project
> Export Project
> Compile Project
> Download Project
RDU : Enabled
Honeywell RDU : Enabled
FireWorks : Enabled
> color Text software
ANA-USA : Enabled
ACDB : Enabled
> Stand alone up to 8 doors
EST Specials : Enabled
EST DLL : NOT Enabled
Brand : Edwards Systems Technology
The HASP Key works fine in W7 32 and 64 bits, I can install without any problems the 3-SDU, and Firework Tool.
Unfortunately, when I run the SKCHECK.exe in W7 32 or 64 bits it doen's work, in constantly throws a "THIS IS NOT A VALID KEY" error. Also, when I run the 2-SDU ver 3.2 it recognize the hasp key but I cannot install the instance, it appears in blank.
Any Suggestions?
Best Regards,
2-SDU 3.32 in Windows 7 32 bits
Re: 2-SDU 3.32 in Windows 7 32 bits
it is a braind-new key,I imagine,
may be the version of the SDU is not compatible with WIN 7 ,it should be 5.2 or higher.
contact your trainer to get more information about compatibilities.
I've got the same problem with fireworks.
regards,
regards,
Well, the problem was 2-SDU has to run in compatibility mode XP SP3, also sdcheck. Any of those doesn't work in 64 bits OS's
ahhhhh!
sorry,
you'r talking about 2-SDU,
cmadradi, u'r right,
sorry,
