M2000PXNplus (Integrated Configuration tool)
M2000PXNplus - Integrated Configuration tool -Default IP - 192.168.6.6 Login/Password - install/install
setup these switches or you will not be able to get login screen from (Integrated Configuration tool)
Set dip switch SW5-6 to OFF.
Set dip switch SW5-7 to OFF.
Set all the other switches on
Secure Perfect:
Address is set with in Integrated Configuration tool for Secure Perfect, not via the Address wheels/rotary dip switches..
with in (Integrated Configuration tool) set host to Secure Perfect, then APPLY CHANGES.
Then go into Controller Info and set the address. (the address box will not appear until you APPLY CHANGES)
